Printer parts STL file - Prusa i3 pro C
Hello
is it possible for you to link or provide printable parts for prusa i3 pro C printer (dual extruder version)?
I would like to print spares, because it seems that some of my plastic parts are breaking apart.
thank you in advance for your answer.
(tried to search the forums but didn't find a thread about prusa i3 pro C)
Re: Printer parts STL file - Prusa i3 pro C
There only old parts for the Prusa i3 pro C
I need to print a new X belt tensioner for my printer. It sits behind the MK8 carriage.
I have checked the I3 C, seems there's no belt tensioner for this printer...do you have a picture for it?
I looks like it called "belt bracket" in the manual
- Prusa i3 pro C belt bracket
- belt bracket.jpg (7.83 KiB) Viewed 25005 times
seems there's no this part on the pro C, have you got the correct brochure? I think the one in the lower left corner of the picture above is just the one you want.
the manual is correct
http://www.geeetech.com/Documents/pro%2 ... ion%20.pdf
I actually already got the STL file from sherry.li@geeetech.cn
The bracket that came with my printer has melted, it may have been made with PLA. I printed some new ones with ABS and nylon and they work very well.
Here is STL file if any one else want to print
- PI3F-B01-BlteClip.STL.zip
- Belt bracket no51
- (37.9 KiB) Downloaded 1342 times
Does anyone have the design file so i can modify the 'belt bracket' to include my induction sensor?
hello,
can you send me the whole stl files like the picture. i need this for repair my damaged geeetech prusa i3 pro c.
thx
thx
Here it is:
download/file.php?id=1669
