I3X Acrylic 8mm /GT2560 hotbed wrong temperature measurement
Torm
Post by Torm »
Hello all,
my printer behaves unexpectedly - the temperature of the hot bed, indicated by firmware (both LCD and PC control software ) does not correspond to the actual temperature measured at the surface with thermometer. When firmware reports temperature 95°C, real temperature is only 76°C, the difference varies between 20-30°C. Some ideas?
Oh, yes, to make matters worse still, I can not reach a temperature higher than about 98°C (LCD), which means about 78°C on the surface. I use sandwich hot bed - aluminium platte - borosilicate glass plate.
Mark
Re: I3X Acrylic 8mm /GT2560 hotbed wrong temperature measure
Post by Mark »
I think the surface is a little far away form the bed center, so it won't be that hot.
And how about the resistanc of your hotbed, it is usually 1.2-1.5ohms, if too high then the temperature won't pass 100 degrees, check this link:
http://www.geeetech.com/forum/viewtopic ... 13&t=17039
Torm
Post by Torm »
Mark wrote:I think the surface is a little far away form the bed center, so it won't be that hot.
Thank you for quick reply, Mark. Hot bed resistance is exactly 1,45 Ohm, voltage 10.1 V. Therefore, current via hot bed is about 7 A. Is it sufficient? At what power is hotbed plate designed ?
Mark
Post by Mark »
should be 12V, 10.1V is a little low.
Torm
Post by Torm »
Yes, Mark, it would confirm my suspicions :) I have a follow-up question - on how input voltage is designed GT2560 board? I ask, therefore, whether it would not be a solution to add voltage on the power PSU, e.g. to 13-14V?
Torm
Post by Torm »
So, after a week of experimentation, I have some results that might help others as well.
1. The power supply I (with trimmer on the PSU) rise up to 13,6V.
2.On the underside Hot bed I attach the adhesive felt pad from a local hobby shop (thickness about 4 mm)
3. When warming, I cover glass with another felt pad, without adhesive layer
To work with the ABS, the hot bed temperature can be preheat to 118 ° C, after removal of the upper felt pad , the temperature drops to about 105 ° C, for sufficient adhesion ABS enough.
Mark
Post by Mark »
thanks for your suggestion, it's really helpful!
sniper1212
Post by sniper1212 »
Torm, can you please explame me how rise you heatbed voltage to 13,6V??
I get only 10,7V on my headbet...
You can test the DC output(around 12V) of the PSU,you can adjust the potentiometer if the output is not sufficient:
