Need help
iron7
Need help
Post by iron7 »
Hi everyone
I have bought an acrylic i3 pro B 3d printer. Today while i was printing suddenly the printer stopped, the lcd screen showed error max temperature. I checked the extruder thermistor, i replaced with an other, i tried to re upload the firmware but nothing worked. The only method that i could manage the printer to work was by replacing the board with arduino mega + ramps 1.4. I bought the printer from geeetech ebay store about 9 months ago. The board from the manufacturer is sanguinololu. Is there something helpful to solve this or simply the board is dead ?
Thank in advance
Mark
Re: Need help
Post by Mark »
iron7
Re: Need help
Post by iron7 »
Dear Mark
I followed step by step the previous guide. When i attached a jumper at extruder's thermistor pins and i got 358 ℃ / 0 ℃ and Err: MAXTEMP as you refer. When the jumper is unplugged, lcd displays 266 / 0 ℃ and Err: MAXTEMP constantly. What else would be causing this issue ?
Mark
Re: Need help
Post by Mark »
since you can make it work using the ramps board, then it might be the sanguinololu's problem. How about reinstall the firmware?
iron7
Re: Need help
Post by iron7 »
I tried to reupload the firmware, the problem continuous. Even when i changed thermistor, the same issue. Something else that can i do to fix it ?
Mark
Re: Need help
Post by Mark »
how about the back of the connector? does the pins have a short with each or not? If not then seems you'll gonna need a new board ..
iron7
Re: Need help
Post by iron7 »
Hi Mark
As you can seen in the attachment, there is no short circuit. Even if it was a short circuit, lcd screen should display 358 C and not 266 C Error. Finally i need a new board ?
Ι bought the printer from geeetech's ebay store at 7th of May 2015. Is there a product warranty ? The receipt id is 2417-5145-6841-2186
Mark
Re: Need help
Post by Mark »
yeah you need to contact the sales on the website to talk about it.
