control board problem
chrisprint
Post by chrisprint »
after inverting stepper direction Z lost all control of printer via LCD board and repetier, help please :cry:
Re: control board problem
chrisprint wrote:after inverting stepper direction Z lost all control of printer via LCD board and repetier, help please :cry:
Ensure the accuracy of your connection to the motherboard and the connection of Z motor's driver module.
chrisprint
i also get (Err;MINTEMP) also the display no longer displays the tempreture of the bed and hot ends
chrisprint
i have two machines, it did it on both
chrisprint wrote:i also get (Err;MINTEMP) also the display no longer displays the tempreture of the bed and hot ends
You can refer to the info below to check it:
chrisprint
i have used diffrent gt2560 boards with the same result!!!!
chrisprint
the board shows err max temp but the display does not indicate temp just 00
chrisprint wrote:the board shows err max temp but the display does not indicate temp just 00
Have you already checked the link i posted?And could you take a pic of your LCD ?
chrisprint
still no result
hope you get this
hope you get this
chrisprint wrote:still no result
Hi,my friend
I think you'd better try to check it again as the links shows,maybe you've missed something.
Good Luck!
