M201 - GTM32 Suggestions & Questions
greeffbf
Post by greeffbf »
I Bought a M201 - with the GTM32 controller via Banggood.
I bought this machine due to few reasons.
1 - GTM32 Controller can handle 3 extruders (No firmware to be found)
2 - Larger Print are 280 x 220
MODS
I replaced the lead screws with 8 x 2mm 4 groove and replaced the Z steppers with 0.9Deg 48mm Nema
I got rid of the flexible couplings on z axis drive to cut out slop. Your configuration make 2 heads not very accurate)
I modified the 2 in 1 head with 2 in 2 head.
I removed the fan on extruders at top. Useless.
I grinded down rod locks to provide maximum travel.
I modified Z axis end stop with lock nut to make more accurate.
I made PTFE tubes as short as possible to get more accuracy when withdrawing filament printing on 2 extruders.
Questions
1 - I use the GTM32-Dual extruder software and every now and then the LCD goes blank. Is this normal?
2 - Sometimes the print just freezes up at various fases of same job (Printing from SD card.) Sometimes prints fine, then freeze at 40 %, then at 67% never the same.
3 - It seems as heating bed element a bit weak to heat up aluminium bed fast. Can you not get higher wattage bed in same size?
4 - Can you please supply firmware so it can do 3 x extruders?
Suggestion
You have great idea but having firmware not accessible makes printer undesirable.
syossi2
Re: M201 - GTM32 Suggestions & Questions
Post by syossi2 »
i with you.....i also put 3rd nozzle
i have 2 in1 and one saparte side by side
but .....
i also ask them to this 2 mounth ago....
that the firmware will recognize this 3 ports thermistor T2 , nozzle 2, extruder 2
and the 3 max end point to make them works and reconize by the firmware
hope they will do it soon
yossi
printing 3D with M201 Geeetech
greeffbf wrote:I Bought a M201 - with the GTM32 controller via Banggood.
MODS
Questions
Suggestion
Hi,my friend
Thank you for your suggestions,we are happy to hear that.
1.I think you can have a try to reset it on controller panel.
2&3.It is about the software and hardware,i'll feed it back to our engineer.
4.I'm afraid that we have no plan to update firmware temporarily for 3 extruder on M201.
Regards
syossi2
Post by syossi2 »
its too bad,,, :(
its so easy just to enabled on firmware the 3 ports thermistor T2 , nozzle 2, extruder 2
pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeee
syossi2
Post by syossi2 »
hi greeffbf
can you explane with picture please the selected mods you have done please?
picture please
picture please
picture please
picture please
?? i try to put also end stop . but the firmwre didnt activat it... so how did you do it?
thanks
yossi
greeffbf
Post by greeffbf »
Pictures as requested
Lead screw and 5mm to 5mm coupling, I turned the lead screw ends down to 5mm
Lead screw Coupling.jpg (156.27 KiB) Viewed 15160 times
Nema Stepper 0.9deg
Nema Stepper 0.9deg
Stepper Nema09_48.jpg (126.8 KiB) Viewed 15160 times
Nema Stepper 0.9deg
Locknut on Z stop min
Locknut on Z-min Stop.jpg (66.52 KiB) Viewed 15160 times
Grinded Bar Locks
Grinded Bar Locks
resized bar locks.jpg (76.38 KiB) Viewed 15160 times
Grinded Bar Locks
Dual Print Head
Dual Print Head
Dual Printhead.jpg (113.73 KiB) Viewed 15160 times
Dual Print Head
syossi2
Post by syossi2 »
So you install the dual head firmware? The old one that here on the website?
Yossi
greeffbf
Post by greeffbf »
Yes, it is called GTM32_Dual.zip and was posted by Mark.
To add z-axis max end stop.
Control ->
Printer Settings ->
Move right down to end stops, select z-max end stop. try the settings. Remember end stop will only work if axis max is greater than end stop position.
syossi2
Post by syossi2 »
so you buy the mk8 dual head?
greeffbf
Post by greeffbf »
No, I bought Two hot ends (the smallest I could get), Two nozzles, Two thermisters and Two 24Volt heaters in order to swap back when I want.
Just remove the last aluminum block 2 into 1. And assemble this. Easy to revert back to 2 in 1 out.
The biggest secret is setting the two heads very accurate same distance from print bed(Main reason why I replaced flexible couplings and lead screws).
Then in Slic3er you specify the offset of the two heads, there is a nice STL file with 4 checker squares you can use to fine tune and play with retract of fillament etc.. Can't remember the name now.
Cheers
Francois
