Firmware for geeetech 3D printers
Locked
formmanufaktur
Re: Firmware for geeetech 3D printers
Post by formmanufaktur »
I would like to use the Prusa I3 M201 with DUAL HEAD, not with MIXED. Could you please add a modified 1.0.5 Firmware for download? Thanks in advance!
formmanufaktur wrote:I would like to use the Prusa I3 M201 with DUAL HEAD, not with MIXED. Could you please add a modified 1.0.5 Firmware for download? Thanks in advance!
Hi,you may want to read this:
http://www.geeetech.com/forum/viewtopic ... 965#p30965
JohnDeere630
Post by JohnDeere630 »
I just bought and put together a prusa i3 aluminum, and am having the reversed x and y stepper motor problem. I downloaded and changed the relevant firmware file, and using win7 and arduino version 1.0.1 as recommended absolutely cannot upload the firmware. It seems to be a usb connection problem; if this issue has been addressed prior, please refer me to the link. I read through a bunch of pages here until my eyes burned, and didn't see it. Thanks.
Fear-Capone
Post by Fear-Capone »
Hi, i have a prusa i3 pro b and the firmware from the 1. Posting.
I have no z offset Menu under Control - Motion.
Is that normal? I want so set the offset online by printer for my Auto bedleveling Sensor.
ggg666
Post by ggg666 »
Fear-Capone wrote:Hi, i have a prusa i3 pro b and the firmware from the 1. Posting.
You can try flashing the firmware again,it should exist cuz i find the setting "Z offset" on I3-x...
Or you can modify it in the firmware,though unconvenient.
ggg666
Post by ggg666 »
JohnDeere630 wrote:Hello,
I guess the firmware can be compiled successfully,but can't be uploaded?Right?You can attach a picture about the error.
Did you select the right COM port or was the board detected successfully by your computer?You can open your device manager to have a look:
Fear-Capone
ggg666 wrote: You can try flashing the firmware again,it should exist cuz i find the setting "Z offset" on I3-x...
I have flash it many Times, no z offset Menu there.
It's fine that i can modify it, i don't know where ich can activate this Option
JohnDeere630
JohnDeere630 wrote:
You are right, Arduino version 1.0.1 compiled it without a problem, and I did have the appropriate COM port selected (It was the only choice anyway). The program says it's uploading, then after a few minutes gives a timeout error. I don't remember the exact wording, but research indicated a connection issue. The board seems to get detected correctly. I have programmed arduinos before, so am familiar with the process. I did solve the reversed stepper problem by rewiring the steppers directly, but would still like to get the firmware issue solved.
I saw this before,but you're using 1.0.1 now...Maybe you can try other versions?
Anomata
Post by Anomata »
I have bought a Rostock 301, built it and checked the version on the display. It stated 1.1.0 A. Is it the 1.0.0.1 firmware available for download or is it something else? Alpha? Totally unrelated?
BR
Anders
Locked
