How to upload firmware for GTM32 Pro board?
Re: The Restock 301(STM32 Pro Board) Firmware Burning Steps
Make sure the Baud Rate and the COM port are all right.
Lami René
Post by Lami René »
Bonjour raoulito9 et William Kwok,
Quel doit-être la vitesse et les autres paramètres pour la communication sur le port COM ?
Sur la carte STM32 Pro, est-ce qu'il n'y aurait pas un cavalier "jumper" a mettre ou a enlever pour permettre la gravure du micrologiciel "firmware" ?
Cordialement,
L'ami René
One for all and all for one !
Lami René
Post by Lami René »
Rebonjour raoulito9 et William Kwok,
Je viens de tomber sur cette page "flashing_rumba_bootloader" :
https://www.nova-labs.org/wiki/3d_print ... bootloader
Il y a peut-être une solution qui fonctionnera pour vous !
Cordialement,
L'ami René
raoulito9
Post by raoulito9 »
Hi this is ok, i found how to flash the new firmware.
If you look at my screenshots, you'll see my printer is connected : correct com port and correct baud rate...
I just missed a little step aof the tuto, bad documented :
When you are connected into hyperterminal, first push C key with the disconnect icon THEN some new chinese chars appears THEN PRESS 1 KEY.... I missed the step of pressing the 1 key before sending the file....
And it is while examining the screenchot of the tuto i found it....
Please, document it better....and add the sentence of pressing the 1 key to your tuto...
Flash is done on my printer , and absolutely no difference for me.
Please release the source codes for this printer.
You all know open source firmware are waYYYYYY better han all you could ever imagine.
Have a good day.
ISURU
Re: How to upload firmware for Rostock 301(GTM32 Pro board)?
Post by ISURU »
HI could anybody please help me to upgrade the firmware version on my Rostock 301
I did everything as explained above.
at last i got a message saying "jump app fail!"
and my lcd screen got stuck.
The Nob/push button doesn`t work.
restarted but still same.
how do I reset? the mother board
thx for any help
ISURU
Post by ISURU »
This is the message i had at the end of upload.
LCD display stopped working.
try to upload the firmware again doesn`t work.
Maybe you missed something?You'd better check if there is something different from the post in your procedure.
ISURU
Post by ISURU »
i have travel several times it doesn`t work.
Lami René
Post by Lami René »
Bonjour,
Quand Geeetech va fournir la procédure pour la mise à jour sous Linux Kubuntu du micrologiciel "Firmeware" pour l'imprimante Rostock 301 et de la carte contrôleur GTM32 Pro ?
Est-ce que Geeetech a des personnes compétentes pour réalise ce travaille ou est-ce que Geeetech est trop pauvre pour embaucher et payer les personnes compétentes et respecter sa parole écrite sur son site Web qui dit « Operating system: Windows/Mac/Linux » ?
Ma version du micrologiciel installer d'usine est 1.1.0 A.
Cordialement,
L'ami René
Lami René
Post by Lami René »
Rebonjour,
En cherchant une solution pour la procédure pour la mise à jour sous Linux Kubuntu du micrologiciel "Firmeware" pour l'imprimante Rostock 301 et de sa carte contrôleur GTM32 Pro, j'ai trouvé dans les dépôts standard de Linux Kubuntu 16.04 64 bits en français le logiciel "CuteCom" (voir le clip-écran).
Je pense que vos techniciens pourraient utiliser ce logiciel pour nous indiquer la configuration et les détails de la procédure à suivre pour graver la dernière version du micrologiciel "Firmeware" pour l'imprimante Rostock 301 et de la carte contrôleur GTM32 Pro sous Linux et respecter son engagement de fournir une solution pour les ordinateurs avec Linux.
Si vos techniciens n'ont as les compétences pour le logiciel CuteCom, en standard sous Linux Kubuntu il y aussi les logiciels Arduino et Moserial, si vos techniciens ont plus de compétence avec ces deux derniers logiciels.
Est-ce que Geeetech a de l'honneur et donne de l'importance à ses clients ?
Nous le verrons très prochainement de la manière qu'ils vont traiter la présente suggestion et les nouvelles solutions avec ces trois logiciels différents !
Cordialement,
L'ami René
P.-s. J'ai l'imprimante depuis le 27 octobre 2016 et je n'ai toujours rien imprimé avec, car Geeetech ne donne pas les solutions à nos problèmes...
Clip-écran du logiciel CuteCom sous Linux Kubuntu 16.04 64 bits
CuteCom Linux Kubuntu 16.04 64 bits.png (39 KiB) Viewed 41140 times
