extruder not pulling enough filament
Rege
Post by Rege »
Hello
My i3 pro B is finally assembled, and after many try i can't get the extruder to work correctly.
Tried many things:
- filament is PLA , 1,75mm tested all Temperature until 230°
- tuned te steps per unit value in the firmware from 93 (original) to 144, with no change in the result
- checked the voltage 12,1V , and also tuned the extruder driver from 0.7V to 1V (other drivers for axes are around 0.8 and works great)
- Changed the Slic3r tuning , finally for a 0.2 mm height print with honeycomb infill, extrusion multiplier 1.2, i can't get any better than enclosed pictures...
Is there some thing that I'm missing?
What can I do ?
Re: extruder not pulling enough filament
You can remove the fan on extruder to check if the extruder motor feeds the filament normally when extruding.
Rege
Post by Rege »
The motor makes the filament move but i think the spring does not press enough ...
Will try to make a video.
Rege
Post by Rege »
Still the same problem
Can someone help me?
I really think that the spring is not strong enough... when I pull the lever with my hand the filament extrudes well.
I've seen in another thread that the aluminium version ok MK8 may be the solution... can someone confim?
Please Geeetech support team help me.
Rege
websmr
Post by websmr »
After two months with problems of extrusion, I finally realized that the problem is in the extruder, specifically in the screw that pushes the filament which slides when pushing plastic because it does not have enough pressure.
The solution was as easy as putting a piece of paper in the extruder's spring, so that it becomes stronger and the filament does not slip when it passes through the screw.
I hope it helps you, tested on two i3 pro B with the same problem, both working perfectly.
@websmr
Great idea...But i'm afraid it can't last too long...
Rege
Post by Rege »
Hello
Thanks @websmr with this feedback, i designed a part to increase the spring pressure
http://www.thingiverse.com/thing:1936289
Using the 4mm version seem the better for me.
Seem to work fine for me - but now the extruder is missing steps sometimes, but the print is really better
See Picture : pikachu before /after
@William: what else would you propose?
websmr
Post by websmr »
Rege wrote:Hello
With this feedback, i designed a part to increase the spring pressure
@Wiliam: what else would you propose?
Seems better now, but i think maybe you have too much pressure, with the piece of paper i have good results, dont missing steps or something.
I measured how many mm has the piece of paper and its 2mm, you should try this version
Rege
Post by Rege »
You were right ...
Today , I tried to prin something, and no feeding at all -> after checking the extruder upper part is broken... maybe too much effort.
I'm really disappointed ...
Tried to contact my seller because without the spring load , there were not enough filament so no good print, and now it is broken...
I added a note on my thingiverse part to prevent other broken parts...
aleXall
Post by aleXall »
Alternative trials / solutions
If pivot is broken,change it with a 3mm screw, to which you have removed head.
