S-180-12 PSU Failiure
Dunderklumpen
Post by Dunderklumpen »
10 seconds after start up, a transistor in the PSU blew up and the printer no longer works.
Re: S-180-12 PSU Failiure
1.First please check if your power supply has switched to correct voltage. please note that ,there is a 110V/220V switch in power supply, switch it to correct position according to residential voltage in your country.
2.Was the green light still on the PSU?If it was,you can measure what value is the DC output of PSU.
If it was't on when your power it on,then the PSU may be broken and you can contact your seller to ask for a PSU replacement.
Dunderklumpen
The PSU is set to the correct voltage(220).
The green light is not on when i power up the PSU.
Hi,it seems like the PSU was broken,you can contact the seller to resend a replacement.
DQW
Post by DQW »
I had this problem after a year of usage, it suddenly stopped working.
I ordered a new one on geeetech after asking the type of my psu. I installed it today and the same thing happens. nothing.
I hear a slight buzz. But nothing powers on?
@DQW
Was the green light(on the PSU) on when you turn it on?You can measure the AC input and DC output with a multimeter.
DQW
Post by DQW »
The green light doesn't go on with the new one. So my guess it wouldn't go on with the older one. The light from the on/of button does go on??????
Did you notice it?The green led will be on when the power is on,and what model is your printer?Did you buy S-180-12 PSU too?
power led.jpg (75.59 KiB) Viewed 16201 times
DQW
Post by DQW »
Same PSU , no the GREEN light doesn't go on but the light from the I/O does go on.
I have the prusa I3 X acrylic.
Cup
Post by Cup »
DQW wrote:Same PSU , no the GREEN light doesn't go on but the light from the I/O does go on.
First check if you have the L/N/G cables correctly connected,then check the 110V/220V switch on the PSU.
The next move is to unplug the board from the PSU and measure the AC input and DC output with a multimeter.
