Firmware Error
Master Chris
Firmware Error
Hi guys
i tried to upload the new firmware when i uploaded it i got a screaching noise and 2 block lines on my LCD
i tried to upload the file again, i have double checked its the right file i have toe geeetech prusa I3 PRO I used the firmware in section 5 of your firmware list
I HAVE AN ERROR EACH TIME I TRY TO LOAD FIRMWARE
I have attached a pic of the error i get
thanks for any help in advance
Chris
Chris
- THIS IS THE ERROR I GET
- 20170513_224630[54].jpg (230.83 KiB) Viewed 15220 times
Master Chris
Re: Firmware Error
Hi Guys
I am still haveing trouble with the firmware
Can someone please send me or point me to a copy i can just load it up
Im vwery new at this programing stuff and I cant seem to get it right
I have downloaded the firmware for the GEEETECH Prusa I3 Pro B
but it seems to have an error and i cant figure out what or how to stop this error
Please help the printer was working ok when i put it together just had a problem with heat bed not getting up to max temp which is why i thought i would try firmware update I installed the wrong 1 at first and have since tried to install the correct 1 for my printer with no luck, I really need a step by step for my particular printer as ive tried the current instructions and have had no luck
thanks for any help
Chris
thanks for any help
Chris
Re: Firmware Error
From what you said, i think it is not caused by the firmware.Master Chris wrote:Hi Guys
thanks for any help
Chris
Maybe the board has some issue.
Can you take a picture show the issue?
Master Chris
Re: Firmware Error
Hi thanks for your reply
what pics would you like the error i get with the firmware and the problem with the printer is all in the top post
the firmware error happes before i even connect to printer and i cant figure out what i need to do to fix it ?
thanks
Chris
thanks
Chris
Master Chris
Re: Firmware Error
I have managed to get the firmware uploaded the screen is now working correctly and no screaching
the problem i now have is that when i connect to the printer using the repetier software the connection button says its connected to printer but i cant control anything from the software, also i manage to manually can move all the axis from the lcd screen i can also heat up the bed manually.
but it wont print from the sd card or from the repetier software
what have i dont wrong and how do i fix this ?
thanks
Chris
thanks
Chris
Re: Firmware Error
Hi,I think you can reinstall the lastest version of Repetier Host to try again,and here is the download link:https://www.repetier.com/download-now/.Besides,changing the usb cable may make it work by Repeiter.
As to the SD printing,here are some tips for this case:
1、Use repetier to put files on SD-card and the G-codes have been also in root directory of SD-card.
2、Check your lcd and cable,make sure they have a good connetion.
3、Try to use some high end SD cards.
4、Reinstall the FTDI drivers.
Hope this can help.
Hope this can help.
Master Chris
Re: Firmware Error
these are the messages im getting when i try to print dont take3 any notice of the temps i did that manually and it was still cooling down
I can move all the xyze through the lcd switch manually but i cant get it to print from either the reipieter software or through SD card the message i get as you can see from the pics is it the count timer goes up when i set it to print from sd but that is all
any help would be apreciated i have tried to change baud rate makes no difference
thanks
chris
thanks
chris
- WIN_20170523_16_04_35_Pro.jpg (200.92 KiB) Viewed 15097 times
- WIN_20170523_16_03_57_Pro.jpg (228.57 KiB) Viewed 15097 times
- WIN_20170523_16_03_50_Pro.jpg (216.3 KiB) Viewed 15097 times
- WIN_20170523_16_03_50_Pro (2).jpg (254.75 KiB) Viewed 15097 times
- WIN_20170523_16_03_40_Pro.jpg (199.55 KiB) Viewed 15097 times
eddiesomesan
Re: Firmware Error
Change the USB cable. Try to use a good quality one and as short as possible. I had some similar issues...it was stopping in the middle of the print showing that communication error. The problem was the cable which was too long.
Master Chris
Re: Firmware Error
Hi Guys
Thanks to everyone for there input i have managed to resolve my problems and I am printing again with some good results.
ABS filament that im using is a bitch to get the settings right but im getting there
thanks again
Chris
thanks again
Chris
