Control Board not releasing power to other parts
smokewoodland
Post by smokewoodland »
After assembling by Geeetech Prusa i3 X, I was getting ready for my first print, which was from an SD card. I clicked preheat PLA, and everything turned off, except for the green lights on the PSU, and the control board. I checked the input to the control board with a volt meter, and it was putting out a full 12 volts. When I plugged the PSU cord to the control board, the control board measures at no volts, anywhere on it. What can I do to fix it?
P.S.-When moving the extruder mount back and forth, the LCD board will light up briefly, and the fans will turn on, and back off. This may be of no importance to the control board problem, but just wanted to add this information in.
Re: Control Board not releasing power to other parts
You can check the voltage of here. Normal is 5V
smokewoodland
Checked that with a volt meter. 0.0
smokewoodland
Don't know if the first post went through, but getting 0.0 volts from there.
Do you remember to plug 12V psu?If you have try it and get the same result,you should contact the related sales at first.
smokewoodland
Yes, I remembered to plug in 12V PSU cord. Guess it was just a faulty board
