E180 Temperature won't Go Above 5-15 Degrees (C)
IlaiFlint
Post by IlaiFlint »
I'm not able to get the E180 to heat beyond about 5-15 degrees, even after about 20 minutes. Any advice?
Re: E180 Temperature won't Go Above 5-15 Degrees (C)
I think you can remove it out and clean it then install it to the printer.
contact point.png (237.82 KiB) Viewed 8475 times
Tipam
Post by Tipam »
Also, if your contacts have noticeably large lumps of solder on them, remove them with a soldering iron ... otherwise contact is bad and temperature readings will be false.
Tipam wrote: Wed Mar 28, 2018 2:15 am Also, if your contacts have noticeably large lumps of solder on them, remove them with a soldering iron ... otherwise contact is bad and temperature readings will be false.
Thanks for your sharing!
