E180 Temperature won't Go Above 5-15 Degrees (C)
I'm not able to get the E180 to heat beyond about 5-15 degrees, even after about 20 minutes. Any advice?
Re: E180 Temperature won't Go Above 5-15 Degrees (C)
I think you can remove it out and clean it then install it to the printer.
- contact point.png (237.82 KiB) Viewed 8480 times
Also, if your contacts have noticeably large lumps of solder on them, remove them with a soldering iron ... otherwise contact is bad and temperature readings will be false.
Thanks for your sharing!Tipam wrote: Wed Mar 28, 2018 2:15 am Also, if your contacts have noticeably large lumps of solder on them, remove them with a soldering iron ... otherwise contact is bad and temperature readings will be false.
