Firmware for geeetech 3D printers
Locked
keyser187
Re: Firmware for geeetech 3D printers
Post by keyser187 »
thanx again but i tried easyprint 3d 1.1.7, updated the firmware in the program but same thing is happening. every time i turn on the printer or connect a usb the motors are struggling to move when i choose "auto home". i have to go to "control->Restore Failsafe" every time i turn on or plug in a usb just to get it to move correctly.
You can change value of the direction of motors and then upload it to the printer
keyser187
Post by keyser187 »
you have lost me?? i havent got a clue how to do that or what you are on about?
im just going to send this thing back, get my money back and save up for an Original prusa. i bet they dont turn their back as soon as you purchase a product!
Post by _kaktus_ »
There is an option in my printer: restore default data.
if you have made modifications to the settings, you may want to use it.
keyser187
Post by keyser187 »
i done a quick video to show what the problem is
https://youtu.be/qSNEYJga-7k
Post by _kaktus_ »
[quote=Mark post_id=27625 time=1444446141 user_id=47216]
[i][size=130] 1) Firmware for Prusa I3 M201[/size][/i]
The latest version(for GTM32) :
GTM32_V1.0.5.zip
[color=#FF0000]For the new board(GTM32 Pro VB)on M201:[/color]
gtm32_machine_m201.zip
[/quote]
The archive with the firmware file, named gtm32_machine_m201.zip contains the software version 1.0.03
I am asking for a new version of the firmware.
RolandTruter
Post by RolandTruter »
Hope you can Help.
I have the I3 M201 with the GTM32 Pro VB board.
I tried doing the firmware update but now I am getting a blank screen and nothing is working
It does not boot up at all.
What I did was I used "Flashed loader demonstrator" to burn the bootloader and then firmware GTM32_V1.0.5.
after the boot loader it just went blank then I done the Firmware update thinking it would sort out the issue.
But nothing.
Did I damage the board? If not how do I fix this issue and how do I revert back to original state?
Your Help will be appreciated.
RolandTruter wrote: Thu Jan 25, 2018 6:29 am Hi
Hope you can Help.
But nothing.
You can burn the bootloader at first and then uploading the firmware via the Easyprint 1.1.7
RolandTruter
[quote=William post_id=82269 time=1516861039 user_id=51382]
[/quote]
Awesome Thank you.
Last Night I did come right at the End.
Here was the issue.
I used "Flash Loader Demonstrator" to update boot loader which was a ".bin" file.
Then I uploaded the firmware V1.0.5 but this time it was a ".hex" file.
This did not work and corrupted my board as I could not choose the correct settings as instructed in the '"how to" post. (800200 was not available.)
So what I the tried was to get a older version but in ".bin" file which I did and it was version 1.0.3 and done the whole process from the start.
This worked 100% and today I am printing.
Now the issue that I have is that I do not have the latest Firmware on my Prusa I3 M201. (V1.0.5)
The firmware file (V1.0.5) that I have is a ".hex" file. Will EasyPrint 1.1.7 successfully upgrade my printer with the ".hex" file Or do I need to convert this to a .bin file and then update it?
You can convert it to BIN file and then upload the firmware
Locked
