A30 firmware.
Admin
A30 firmware.
Post by Admin »
If the Z axis endstop of your A30 is on the bottom , you can install this firmware.
Connect your printer to your computer with USB cable, then choose the right COM port.
choose the right version, then click "upgrade"
upgrade.zip
(7.44 MiB) Downloaded 3038 times
vadimnv66
Re: A30 firmware.
Post by vadimnv66 »
Hi !
I have the A30 c EndStop located at the top, but it's not very convenient ((
I want to remake to the bottom
How can I do this - please give instructions
Thank you, Vadim
nitro_sport2003
Re: A30 firmware.
Post by nitro_sport2003 »
Hi do i need to put a jumper plug on board before connecting the usb cable to computer?
Re: A30 firmware.
Post by _kaktus_ »
Generally, you can do this before turning on the power.
Alternatively, if the power supply is switched on, when you put on the jumper cap, press reset.
The bootloader will then be active.
nitro_sport2003
Re: A30 firmware help please
Hi can not get the firmware to load onto the A30 its a brand new board never had software uploaded onto it before is there something else i have to do before i can load the firmware to it? or could it be a issue with my computer not linking to motherboard with USB cable because i'm using windows 10 any ideas? answers please let me know i download the A30 kit firmware but wont upload firmware to board.
Alienmoon
Re: A30 firmware.
Post by Alienmoon »
Admin wrote: Sat Feb 24, 2018 3:26 pm If the Z axis endstop of your A30 is on the bottom , you can install this firmware.
upgrade.zip
@Admin
Hello,... I'd like to ask you a few questions about the A30.
Q1: I've been trying to find what type of Firmware, the A30 is using,... however, I can't find the name of it, is it a Marlin branch or something other than Marlin?
Q2: The other question I have is about the Mainboard type,... What is the name / Model of the Mainboard / Motherboard, within the Control Box?
The Prusa i3 PRO B mainboard is a GT2560 A+,... what is inside the control Box for the A30?
Thank You.
I Want To Believe
Gingko
Re: A30 firmware.
Post by Gingko »
Alienmoon wrote: Wed Jun 20, 2018 6:05 am
@Admin
Thank You.
1, It's not Marlin firmware, it names Smartto, developed by Geeetech and is also opensource now. You can check the version from LCD.
More information: https://github.com/Geeetech3D/Smartto/
2, Mainboard type for A30 is GTM32 mini s.
Alienmoon
Re: A30 firmware.
Post by Alienmoon »
Thanks, for this information, this has been something I've looked for since receiving the GEEETech A30.
Thanks, again.
I Want To Believe
Uranium
Re: A30 firmware.
Post by Uranium »
Bonjour,
Est-il possible d'avoir un tutoriel pour savoir compiler le firmware ???
Sur GitHub ( https://github.com/Geeetech3D/Smartto ), j'ai vu qu'il existe la version A30_V1.37.59, comment fait-on pour l'installer sur nos imprimantes ??
Merci de votre réponse
Gingko
Re: A30 firmware.
Post by Gingko »
Uranium wrote: Tue Jul 03, 2018 2:14 am Bonjour,
You can download the newest .bin file first, then use Smartto firmware tool to upgrade it.
http://geeetech.com/firmware/
https://github.com/Geeetech3D/Smartto/b ... forWin.zip
