unload filament
unload filament
i can't remove the filament to replace it with the new one. What is the correct procedure?
Re: unload filament
You need heating the nozzle at first then you can remove it off.
Re: unload filament
I'm unable to remove filament from the print head, I've tried heating the extruder but it still will not come out. What am I doing wrong.
Thank you for any help.
rjorthmann
rjorthmann
Re: unload filament
1.Heating it up to 220C
2.Then press the pressure bar
3.Refer to this video and then load the filament again
https://www.youtube.com/watch?v=3iS8YU_TNEw
Re: unload filament
I've noticed a problem that I saw on the original build "ERR:MAXTEMP". The Print head has a thermistor that is broke, I can change the temperature now movining the thermistor wires. Is this something I can replace ?
Thank you
rjorthmann
Thank you
rjorthmann
Re: unload filament
You can get it easily.rjorthmann wrote: Fri Mar 30, 2018 8:19 am I've noticed a problem that I saw on the original build "ERR:MAXTEMP". The Print head has a thermistor that is broke, I can change the temperature now movining the thermistor wires. Is this something I can replace ?
Thank you
rjorthmann
It is a 100K thermistor.
You can get it from local
