USB driver for your printer
Admin
Post by Admin »
Before Install
When you connect your printer to your computer, and your computer can not detect the printer like the picture shows, you need to install the driver for it.
Unknow device.png (38.33 KiB) Viewed 115471 times
The first thing you need to do is check your USB communication chip, there are two type: FT232 and CH340. you can check the chip near the USB port. Usually, FT232 is a square, and CH340 is a rectangle
CH340
FT232
Drivers
Update
you can download from this link:
——————————————https://www.geeetech.com/download.html?download_id=40
1.If your USB communication chip is CH340,you can refer to this link.
Windows
Support X86 and X64(Included user instructions)
http://www.wch.cn/download/CH341SER_EXE.html
Mac
http://www.wch.cn/download/CH341SER_MAC_ZIP.html
Linux
http://www.wch.cn/download/CH341SER_LINUX_ZIP.html
2.If your USB communication chip is FT232
Installation Guide:
https://www.ftdichip.com/Support/Docume ... Guides.htm
Windows
X86
https://www.ftdichip.com/Drivers/CDM/CD ... tified.zip
X64
MAC(Mac OS X
10.4 Tiger or later)
https://www.ftdichip.com/Drivers/D2XX/M ... X1.4.4.dmg
Linux
X86(32bit)
https://www.ftdichip.com/Drivers/D2XX/L ... 6-1.4.8.gz
X64(64bit)
https://www.ftdichip.com/Drivers/D2XX/L ... 4-1.4.8.gz
For more info for FT232:
https://www.ftdichip.com/Drivers/D2XX.htm
If the drivers install correctly, you will find these on the device manager:
Drivers work.png (36.56 KiB) Viewed 115468 times
For FT232
For CH340
Ali Mir
Re: USB driver for your printer
Post by Ali Mir »
thaks dear,
i'll try after test i'll told you feedback
thanks
Ali Mir
Post by Ali Mir »
dear ,
thanks for all
i Succeeded now i can control by from my pc
yesterday i already maked download 3d model from web but printed out said work area . i think it's need setting
can you tell me how i can get model Fits printer settings from web
thanks
Gingko
Post by Gingko »
[quote="Ali Mir" post_id=84079 time=1525719313 user_id=65355]
dear ,
thanks for all
thanks
[/quote]
Which slicer software are you using?
You can adjust it with slicer software, "center" the object, or enter x/y value to change position or even change the scale of the model and so on.
octaviostyle
Post by octaviostyle »
I need the easy print software download link for my MacBook . I keep seeing downloads for windows but no MAC
yorkie1
Post by yorkie1 »
when i click connect on Easy Print the message i get is Access to Com port 3 denied, I have tried all the links on Geeetech none opened for me to install driver.
Post by _kaktus_ »
Hi.
This problem is due to your operating system.
Try to work with administrator privileges.
yorkie1
Post by yorkie1 »
Problem sorted thank you, But one more I hope that can be resolved, When i open EasyPrint 3D it says Download latest Version V1.1.7 I click on it and the bar stays at 0% no matter how long I leave it.
Post by _kaktus_ »
:P
New problem = new topic.
Astromxhgo
Post by Astromxhgo »
Hi, I've tried to install my 3D printer I already install the controller and the bus serial is fine.But the problem of "Access to COM Port 3 persists. I hope someone could help me with this.
Locked
