A thermistor in the head (hot end) and in the work table (heat bed)
Post by _kaktus_ »
Hello.
A question to staff.
Please specify the types of thermistors used to measure the temperature in the head (hot end), and in the work table (heat bed).
Gingko
Re: A thermistor in the head (hot end) and in the work table (hot bed)
Post by Gingko »
"100k thermistor - best choice for EPCOS 100k (4.7k pullup)"
Post by _kaktus_ »
Thank you, Gingko, for your reply.
So I understand that in both places there is mounted a glass thermistor NTC 100kΩ.
And whether you are able to specify a series.
Re:A thermistor in the head (hot end) and in the work table (heat bed)
Post by _kaktus_ »
The element with axial arrangement of leads is most probably the MF58 series.
http://en.ampron.com/prod_view.aspx
seria MF58
seria MF58
The second type of thermistor can be the MF58D series.
seria MF58D
seria MF58D
