New mother card works but problem Z axis
regisregis
Re: New mother card works but problem Z axis
Post by regisregis »
Thanks, yes. it works now :)
But again a problem, my first print is an horror!
The filament doesn't move verry well, heating not very well with your green filament. not liquid!
head : 220° , filament compact...
Gingko
Post by Gingko »
[quote=regisregis post_id=84344 time=1527538273 user_id=65381]
[/quote]
Could you show up more details with video or photos?
or you can check these posts first:
viewtopic.php?f=19&t=17097
viewtopic.php?f=19&t=18507
regisregis
Yes i Have :
https://drive.google.com/open?id=11AD7k ... land5tj2TA
a red light on my card when it heats
Gingko
Post by Gingko »
[quote=regisregis post_id=84352 time=1527598547 user_id=65381]
Yes i Have :
[/quote]
It seems that the filament can put out smoothly, then it just cools down in the air.
The nozzle is too high and far away from hotbed so that filament cannot stick on it.
You can level the bed first according to user manual.
Nozzle too hight or too low.jpg (42.71 KiB) Viewed 11901 times
regisregis
But it does not go out whatever the level of the head
regisregis
again me :)
I can print a cube, but what's type of filament send with the print? because i'm heating more 225°and the quality is bad.
Look
https://drive.google.com/file/d/1jKL1KK ... sp=sharing
https://drive.google.com/file/d/1l17X9c ... sp=sharing
Regards
Gingko
Post by Gingko »
[quote=regisregis post_id=84429 time=1528041696 user_id=65381]
again me :)
Look
Regards
[/quote]
HI! I saw your video.
The filament sent with the printer is PLA,
hotend temp: 190-210C
hotbed temp: 60-75C
I think you can increase the infill density.
I also notice that there is some layer shift with the cube.
You can check if is the voltage of A4988(X-axis) a little low.
And check the belt, maybe it's not tight enough.
infill density.jpg (39.87 KiB) Viewed 11831 times
regisregis
you can specify :
regisregis
I think a problem with buse or extruder, i buy a ABS 1.75
but the extruder accepts 1.75? or only 3? Because in the configuration, you can change the configuration E3 diameter min 2mn.
I can use 1.75 filament?
Gingko
Post by Gingko »
regisregis wrote: Sun Jun 10, 2018 3:25 pm Hi,
Yes, you can use 1.75mm ABS.
It's not possible to change the setting to 1.75mm?
Change another slice software like repetier host to have a try.
