Unnecessary top cover
Morogorn
Post by Morogorn »
Greetings,
I use SketchUp 8.0, to design a RC wheel, export as .STL and .OBJ.
Import to Repetier Host and Slice with CuraEngine.
After repair the object, the wheel show a top cover.
How remove or not print this unnecessary top cover?
I try mark "Spiralize contour", not work.
Someone can help-me?
Best regards.
My printer is: Geeetech prusa I3 A Pro 3D
Re: Unnecessary top cover
Post by _kaktus_ »
Hello.
You wrote:
Morogorn wrote: Wed Nov 14, 2018 7:09 pm After repair the object, the wheel show a top cover.
What was the reason for this operation :?:
Maybe it introduces a problem.
Morogorn
Post by Morogorn »
Thank for your reply _Kaktus_.
The message showed is:
Than I try slice without repair.
Not work.
Post by _kaktus_ »
Would you agree to share your model with us before repair?
I will see what can be done.
:D
Morogorn
Post by Morogorn »
Ok, it's here.
wheel.zip
(162.54 KiB) Downloaded 884 times
Post by _kaktus_ »
Check it out now.
wheel2.zip
(23.01 KiB) Downloaded 778 times
Morogorn
Post by Morogorn »
Wow!
Perfect! What it's mistery?
Post by _kaktus_ »
The best thing is that I didn't do anything with your model.
I imported in Tinkercad, set the position to the grid, and did the export. :lol:
Sometimes I ignored this message, and printed without repair. :roll:
Morogorn
Post by Morogorn »
Thank you _Kaktus_.
:D
Post by _kaktus_ »
