Layer Shifting
Sneakers
Layer Shifting
Post by Sneakers »
So.... I'm getting some pretty bad layer shifts.. I checked the obvious. The bed moves freely and doesn't catch. The belt doesn't seem too tight to me.
I've been having a really hard time printing anything on this printer. I've tried Cura with the profile that's on forum. I couldn't get anything to stick to the bed. So I tried out Slic3r.
First layer went down pretty smoothly.
My travel speed was 120 mm/s ; That was probably a bit high. I'll lower that for sure.
Print speed was 60 mm/s
So after printing like this for 2 hrs, is the stepper motor toast?
Sneakers
Re: Layer Shifting
Post by Sneakers »
So I slowed down the travel and print speed and tried again. The second guy came out pretty good.
I'm working with Slic3r 1.29.
Re: Layer Shifting
Post by _kaktus_ »
:D
Cinderblockx7
Re: Layer Shifting
Post by Cinderblockx7 »
i had a similar issue when i first got my a10 . the belts seemed fine but i snugged em up a tad and it fixed everything. i plan on putting printed tensioners on so i can adjust on the fly!
Sneakers
Re: Layer Shifting
Post by Sneakers »
I need to try that.
I did tighten up all my belts and Y carriage. But it turns out I had them too tight. Also, I had the A10 printing the infill at 80mm/s. So that's why I had the crazy layer shifting.
Gandire48
Re: Layer Shifting
Post by Gandire48 »
My a-10 is shifting ocastionally all in the "Y+" direction. Running "ABS" at 250* ,bed at 80* speed 90-100%, Flowrate 80%. am I pushing too much filament out and dragging the nozzele. ?? But it only skip shifts in the "Y+" axis ??
Re: Layer Shifting
Maybe you can refer to these:
1.The V-wheel is good or broken
2.Loose the V-wheel a little
3.Check the vref of the A4988(You can refer the FAQ of the A10)
4.Check the speed of the travel
5.Check the motor move normal or not(You can swap them then you can know the result)
Tparent
Re: Layer Shifting
Post by Tparent »
Just decrease the YJERK value using menu : "Control / Move / Jerk / YJerk and specify 10 in place of 20 which is the default value
If it solves your issue don't forget to Store your settings (if not savec, value will be reinitialised to default at next switch ON
Hope it helps
Thierry
(+3 x Kossel)
Mostly PLA
