Just assembled ...but...head leakage
There is some kind of fatality (or really unlucky)
I had a lot of issue before being able to make stick my print....
Investigating further, I discovered that the print didn't stay flat but had some "large drop" randomly
On the basis of the joined pictures, I have the feeling that the main reason is a PLA leakage.
I'm not really enthusiast to try to fix by myself, the printer being brand new (just unpacked yesterday) and the assembly of the head looking complex
Is this a common issue ?
Do you already encountered this (maybe defective series) ?
I guess that contacting the seller is the best thing to do.
Thierry
Thierry
- IMG_20181007_103102.jpg (393.11 KiB) Viewed 20481 times
- IMG_20181007_103152.jpg (220.78 KiB) Viewed 20481 times
(+3 x Kossel)
Mostly PLA
(+3 x Kossel)
Mostly PLA
Re: Just assembled ...but...head leakage
Did you heat it up after assembly and then perform the final tightening of hotend components while it's hot? If not, give it a try.
Geeetech A10 (with mods) + Geeetech A10M
Repetier Server on Raspberry PI 3, connected to printers for remote printing/firmware uploads.
Slic3r Prusa Edition, Simplify3D, Ultimaker Cura, Repetier host on the PC
Hi. I have the same problem. Did this solution result?
I have the same problem, and I have read it often.
Also in the reviews on Amazon.
Geeetech, what are you going to do about it?
Are we getting a new improved Hotend sent?
I have already written to Arron, and wait for an answer.
For me this is a guarantee case and I firmly believe that Geeetech will find a solution.
Until now, I have always been helped very well.
Greetings Norbert
Greetings Norbert
- received_2217447061612651.jpeg (150.68 KiB) Viewed 20260 times
- received_708373916204872.jpeg (138.49 KiB) Viewed 20260 times
I purchased a new "head" on geeetech spare part site and it solved the issue.
(+3 x Kossel)
Mostly PLA
(+3 x Kossel)
Mostly PLA
You can ask the sales to send you the new version hotend.jupesch wrote: Sat Nov 17, 2018 5:42 am Hello,
I have the same problem, and I have read it often.![]()
Geeetech, what are you going to do about it?![]()
Are we getting a new improved Hotend sent?![]()
Until now, I have always been helped very well.![]()
Greetings Norbert
The old vesion hotend exist this issue,we improved it.
Hi William,
THX, the new one is arrived and works great.
I have the same issue, but not so much as yours. I have this one: SKU:700-001-1121 <-- is this the old one?
WhippingBoy
Is this the spare part you mean?
https://www.geeetech.com/geeetech-a10-a ... -1041.html
Yes, this one.
