A10M - freshly assembled, turns on, all LCD symbols solid
millenium7
Post by millenium7 »
I received my A10M, assembled it and when I plug it in and turn it on, the fans spin, a couple red LED's come on on the unit itself, but the screen is lit up with all symbols filled in and doesn't appear to be responsive. I don't know if it has a beeper but pressing the button or turning the wheel does nothing
I've tried turning it off and on a few times, always the same. I tried reconnecting the LCD cable a few times, it's firmly in and connected. I had a quick look at the board I can't see anything obvious. I connected the 3D Touch and that cycles a couple times on first startup, dunno if that says anything
Anyone know whats going on?
Re: A10M - freshly assembled, turns on, all LCD symbols solid
Post by _kaktus_ »
Hello.
You should load the firmware.
But please don't ask what where and how, just start reading the forum.
millenium7
So it doesn't come with firmware out of the box?
millenium7
I'm trying to update the firmware but i'm just getting this
Yes i'm using the correct COM port. Tried restarting the printer same thing
carre82
Post by carre82 »
first assembly
mine if not lighting at all
only d5 led on mainboard lights steady state
Ask the sales to send you the new motherboard. :shock:
Post by _kaktus_ »
Hello.
vert wrote: Wed Nov 28, 2018 11:03 pm I get the same thing bootloader corrupted on me.
I agree with this opinion.
After the firmware has been loaded correctly, everything should work as it should.
I mean: application program + bootloader.
3dGenie
Post by 3dGenie »
Looks like a fried bootloader to me. Had the same issue on my Anet A8. Try this
https://www.instructables.com/id/HOW-TO ... DUINO-UNO/
