E180 extruder
Chuck240
E180 extruder
Post by Chuck240 »
I have had nothing but trouble from day one with this printer. I have been back and forth between Geeetech and Gearbest for service. Their final answer today was its not repairable or cannot replace it or refund. My extruder gets hot, the brass wheel is sinking into the filament, the filament ends up retracting farther than it extrudes, leading to failed prints. My nozzles have failed and they wont replace them. I am using a borrowed nozzle now for troubleshooting. Any ideas for a replacement extruder?? Thanks
Re: E180 extruder
Post by _kaktus_ »
Hello Chuck240.
Have you tried to unscrew and clean the extruder?
Perhaps it was blocked and that's where the problems came from. This happens if you don't do conservation from time to time.
If the filament does not have the required quality then it is conducive to clogging the extruder. :roll:
Chuck240
Re: E180 extruder
Post by Chuck240 »
The extruder works fine when you manually run it. While the print is running it retracts too far and does not come back to the original feed position. I ran old gcode prints that worked in the past, and they fail, so I don't believe its has anything to do with the slicer. I increased the board voltage to .9 volts, made no difference, except the motor go real hot. Turned it back down to .45 volts. The gear is tight on the shaft, spring tension is fine. The nozzle temp is good also. I would like to down grade the firmware back a few versions, all this started after the update.
apak
Re: E180 extruder
Post by apak »
stock extruder is rubbish, change it for a titan clon, or a bondtech clon, and get rid of any troubles...also change the nozzle and put a V6 clone...
Trademarkos
Re: E180 extruder
Post by Trademarkos »
apak wrote: Wed Dec 19, 2018 5:33 pm stock extruder is rubbish, change it for a titan clon, or a bondtech clon, and get rid of any troubles...also change the nozzle and put a V6 clone...
Currently I am very unhappy with the printer's E180 nozzles (horrible).
I have 3 obstructed and it is impossible to use them (unusable). The nozzles are poorly manufactured and sooner or later the extruder be blocked ...
@apak Could you share the .STL to change all complete nozzle/extruder and place a titanium clone or similar like yours? Thanks friend.
apak
Re: E180 extruder
Post by apak »
Trademarkos wrote: Tue May 28, 2019 11:30 pm
No can do!!! It´s not mine to release, I am helping the developer (Carlos Arruti) but he´s got very busy and not much done for months...still need to improve cooling, but I am pretty sure he will release it.
Sonic_Cloud
Re: E180 extruder
Post by Sonic_Cloud »
Hey apak, I have been struggling to find some help on this, I am looking to change the hotend on my e180 but I am having a nightmare with the pid setting. Could you help point me in the right direction on how to get that sorted
apak
Re: E180 extruder
Post by apak »
This are my V6 settings for PID, but I´ve already got rid of smartoo
That´s an easy mod, cheat, and with excelent prints after that.
https://www.thingiverse.com/thing:3680288
There you have details for changing the board, and the V6 X carriage mounts....by Carlos Arruti
settings E180 V6 01-19.PNG (28.58 KiB) Viewed 49298 times
apak
Re: E180 extruder
Post by apak »
Trademarkos
Re: E180 extruder
apak wrote: Sat Jun 15, 2019 8:11 pm This are my V6 settings for PID, but I´ve already got rid of smartoo
Great, very useful information!
finally I have assembled mk8 kit (CR-10): https://www.thingiverse.com/thing:3298013
Now it prints much better, and also the nozzles do not get stuck. I just need to adjust the steps.
Thx for sharing your configuration, I'm very grateful :)
