USB cable burning when printer is powered on
barker1889
Post by barker1889 »
I've built the printer and checked it is working from the LCD controller. The axis all move and I can use the auto home function.
I began setting it up with Repetier. I connected the USB to my PC and managed to get connected using the Repetier software.
I then switched on the main power to the printer and almost immediately the USB socket on my PC began smoking, I also noticed the cable was very hot. Since then my computer will no longer recognise it as a USB device.
The printer is still working from the LCD controller (and luckily so is my USB port) but each time I plug it into my PC the USB cable starts overheating.
What could be the problem here?
Re: USB cable burning when printer is powered on
Post by _kaktus_ »
Hello.
Specify the version of the controller board you have and place a photo on which it will show the area around the USB port of your controller board.
What happens is not your fault. :D
barker1889
The board is a GT2560 REV A+
Pictures attached
barker1889
Picutres
Post by _kaktus_ »
Hi.
I expect that if you unsolder the resistor marked F2 everything will work properly.
I have described in detail in this topic.
In addition, the printer and computer should be plugged into the same power outlet.
barker1889
I've removed the F2 resistor but I still have the same problem.
The computer and printer are both in the same power outlet (I've checked they use the same ground).
I've checked the voltage going between the ground of the printer and ground of the PC - I got 0.19v which shouldn't be enough to burn a USB cable?
Is there anything else you would suggest trying?
I'm going to try and get a replacement GT2560 board in case there is an issue with that.
Post by _kaktus_ »
Hi.
I am troubled by the failure. :roll:
And are you able to get another PSU for testing :?:
333ppp
Post by 333ppp »
A mi me paso lo mismo y la solución fue desconectar la toma de tierra de la fuente de alimentación.
BR365
Post by BR365 »
barker1889 wrote: Sun Feb 03, 2019 10:16 pmPicutres
It looks like there is a short circuit from the upper right soldier point to the ground.
Do you have a soldering iron to fix it?
Post by _kaktus_ »
Hi.
The short circuit you noticed is awful. It contains data outputs D+ and D-.
This will disable communication to the printer but is not dangerous for electronics.
