Extruder feed wheel jumping backward
ricky007
Re: Extruder feed wheel jumping backward
Post by ricky007 »
okay, here again. Should be sleeping but you know how it is!
Light bulb moment I think.The part shown in my previous post is a spiral and when I played the slicer through the layers i found that in the initial layers the nozzle would travel from the spiral centre to the outer wall at the end of the spiral staying within the path of the spiral. This took some time.
So my theory is that the filament wasn't primed when it reached the start of extruding. this explains the gaps hown in the photo to the right of the boss.
Similarly, half way up the bore of the boss the inner walls fail. This also shows a change of print pattern. if you look closely you'll see thatfailure of print in the bore starts where the failure of print on the outer wall starts. In the slicer when i play the movement through the nozzle moves from the centre of the spiral to the inner wall of the boss. Again this is a long movement where the travel follows the path of the spiral whilst the filament is retracted.
My problem now is what settings to change to overcome this.
Any ideas guys and gals?
thanks for listening to my ramblings, even if no one answers it helps to get my thoughts in line.
Post by _kaktus_ »
Hello.
Would you like to share your model in STL format, and a ready-made Gcode file?
I will try to print them on my printer. :D
The uploaded files must be compressed e.g. in ZIP format.
chrisnasulea
Post by chrisnasulea »
Hey everyone, I seem to be struggling with the same skipping problem you've been having.
Since getting my i3 pro C I printed using some black filament without problems. I have now switched to a brand new roll of white filament and for the life of me I can't get it to print without the dreaded filament skipping sound and missing layers messing up the print.
When you speak of voltage adjustment do you mean from the little adjustment dial on the power source?
Post by _kaktus_ »
Hi chrisnasulea.
chrisnasulea wrote: Sun Mar 03, 2019 12:05 pm ...
Most probably it is about regulating the Vref voltage in the spepstick module. This allows you to increase (or decrease) the power of the stepper motor.
chrisnasulea
Super helpful and fast as usual, _kaktus_ :)
Thank you!
