I can't get my bed level manually. I wasted several days trying to get the platform level without success. The four corners are now good but the center is still not sticking well. I did not have this problem before I disassembled my hotend due to a clog. I'm totally puzzled and at the point of giving up.
Will adding an auto-leveling sensor alleviate the bed leveling permanently?
Problem with Bed Leveling
Re: Problem with Bed Leveling
1.If you use the auto level sensor for it.
You can set the 25 points mode for it then it will work perfectly.
2.I think you should check the wheels of the x/y axis
Maybe it loose,try to tight it
Perfect just what I was looking for!
How to set 25 points ???
Hi,you can refer to these line:
Thanks William
i need change 3 to 5... true?
How is it going on?
Did it work for your printer?
