Y-Axis doesnt work
General Pope
Y-Axis doesnt work
Post by General Pope »
I think the stepmotor-driver and the mainboard-port are broken.
Want conformation or possible other error sources.
But how do i think the stepmotor-driver and the mainboard-port is broken:
I can control the y-motor with the same wire from the x-Port.
->stepmotor and wire - okey
If i take the stepmotor-driver from the y-port and try to control the x-Motor, on the x Port, nothing happens
->stepmotordriver is broken
If i take the stepmotordriver from the x-port (x-axis works fine) and plug it on the y-Port on the Mainboard, nothing happens too.
->Mainboard defekt/y-Port broken
Am i correct or do i oversee something crucial?
Thankful for every input
Re: Y-Axus doesnt work
Post by _kaktus_ »
Hello.
Still tell me if you used the same cable or different :?:
General Pope
i tired with different cables, and the cable (i called it wire) worked fine.
Re: Y-Axis doesnt work
Post by _kaktus_ »
Ok.
I overlooked you wrote about it. :oops:
General Pope
so am i right about my conclusion the stepmoter driver and the main board are broken or are there any other error sources i may overlooked?
Post by _kaktus_ »
Hi.
Your observations seem to be correct.
I would have done the same thing myself. :D
General Pope
Thank you
