Using the 2-in-1out hotend with a G2s Pro
myattorneyusa
Re: Using the 2-in-1out hotend with a G2s Pro
Post by myattorneyusa »
Thank you Mark for reply, you got it right! "G2S extruder2 drives axial motors when printing". The solution linkhttp://www.geeetech.com/forum/viewtopic ... 13&t=17064 you suggested, did work for double hotend (two thermo sensors and two heating elements). It's complicated with Delta 3D printer and mixing hotend (one thermo sensor and one heating element with 2 or 3 extruders).
G2S 2in 1 hotend mount
2in1 G2S.JPG (202.84 KiB) Viewed 8369 times
E0 Printing single color
G2S fan and 2in 1 hotend
2in1 hotend.JPG (264.2 KiB) Viewed 8369 times
BTW, sometimes i can see in the system log something like "E1, communication error, system resetting"
glad it worked haha. but the communication thing you said, never seen it before...
myattorneyusa
2in 1 mount 4 G2S 3D printer
"E1, communication error, system resetting" It's gone after upgrading to new firmware.
2in 1 hotend mount
2in 1 hotend mount
Another thing, don't change axes "reverse true/false" in configuration.h, use defaults or Delta 3D printer will malfunction.
Thank you Mark!
