There is no process bar or anything that say the process is running/completed, how do I know if its working ?
New Firmware toolkits for E180/A30/D200
Re: Toolkits for E180/A30/D200
Usually, it will have a process bar, you sure connected successfully?ariel.ramraz@gmail.com wrote: Sun Jun 17, 2018 2:45 pm Hello,
I'm getting this on running the toolkit too.sasoromih.a@gmail.com wrote: Fri Jun 01, 2018 3:32 pm I keep receiving "Fail to execute script main". Solution anyone?
Is there any answer yet ?
If you put the execution in path with non english characters, it may throw this exception.BennyBoyW wrote: Sat Jul 14, 2018 2:54 amI'm getting this on running the toolkit too.sasoromih.a@gmail.com wrote: Fri Jun 01, 2018 3:32 pm I keep receiving "Fail to execute script main". Solution anyone?
BTW, the latest version was uploaded to our Github, you can follow it.
https://github.com/Geeetech3D/Smartto-E ... ster/tools
If you still not solve the problems, please PM me.
You need Administrator Rights to install.BennyBoyW wrote: Sat Jul 14, 2018 2:54 amI'm getting this on running the toolkit too.sasoromih.a@gmail.com wrote: Fri Jun 01, 2018 3:32 pm I keep receiving "Fail to execute script main". Solution anyone?
Please klick the right mouse button onto the File and say: "Run as Administrator"
make your own world - with 3D printing -
My projects on Thingiverse
my own Geeetech A10 firmware
Geeetech A10 LIVE (not always online)
I think the answer was to put the file in a directory where I knew there were no special characters.
I had already given it admin rights.
The only other thing I did was to put the SD card in the back of the printer, which I hadn't done previously.
Anyway - after all that, it worked a treat
Thanks for the help guys
