I need help setting up my I3 Pro W.
Re: I need help setting up my I3 Pro W.
Hello, William,
i have downloaded a test cube from thingiverse.i attach a file.
i can't get text data loaded, i have two pictures attached.
which data format can i use for the g code that i can upload it.
greeting Arndt
greeting Arndt
- IMG_5848.jpg (656.15 KiB) Viewed 10178 times
- IMG_5847.jpg (724.11 KiB) Viewed 10178 times
- Bild 5.jpg (255.68 KiB) Viewed 10178 times
- Bild 4.jpg (208.74 KiB) Viewed 10178 times
Hello, William,
the printer's going crazy, so I'm sending some more information.
greeting Arndt
10:41:03.509 : echo: External Reset
10:41:03.510 : Marlin1.0.05
10:41:03.512 : echo: Last Updated: Jun 27 2018 16:19:24 | Author: (geeetech, I3 config)
10:41:03.514 : Compiled: Jun 27 2018
10:41:03.516 : echo: Free Memory: 3902 PlannerBufferBytes: 1232
10:41:03.518 : echo:Stored settings retrieved
10:41:06.968 : echo:SD init fail
10:41:07.003 : FIRMWARE_NAME:V1.0.05 Sprinter/grbl mashup for gen6 FIRMWARE_URL:https://github.com/Ultimaker/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:I3proB EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
10:41:07.003 : 0123456789abcdef
10:41:07.003 : hardware:v1.05
10:41:07.026 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
10:41:07.027 : echo:Active Extruder: 0
10:41:07.027 : Begin file list
10:41:07.027 : End file list
10:41:07.033 : echo:Active Extruder: 0
10:42:46.962 : Preferred name from C:\Users\Arndt und Alex\Documents\3D Drucker\Thingiverse\Testdruck\PROW-pillarTEST.gcode to PROW-pillarTEST
10:48:25.545 : Drucke Layer 1 von 200
10:48:56.840 : Drucke Layer 2 von 200
greeting Arndt
- IMG_5852.jpg (273.18 KiB) Viewed 10174 times
- IMG_5851.jpg (190.34 KiB) Viewed 10174 times
We can solve it together.
Good William,
I ran a press on the SD card yesterday.
Feed I calibrated the pressure, put it in the home position four or five times and repeatedly pressed Set Home offsets. Then I printed the test you sent me. But there is something wrong with the filament quantity see pictures. Greeting ArndtGood William,
and before printing whether to level the hotbed?
Hello, William,
I have now added pictures.
Sorry for my language i work with a translation program i am not so good in english language
Greetings Arndt
Greetings Arndt
- IMG_5868.jpg (203.69 KiB) Viewed 10135 times
- IMG_5871.jpg (191.89 KiB) Viewed 10135 times
Im having this same issue on a new build, was this ever resolved?
Hi,You need to check your settings for the consumable diameter in the sectioning software,Lukas71 wrote: Thu Jan 16, 2020 4:13 pm Good William,
Feed I calibrated the pressure, put it in the home position four or five times and repeatedly pressed Set Home offsets. Then I printed the test you sent me.bild7.JPGIMG_5863.jpg But there is something wrong with the filament quantity see pictures.IMG_5867.jpgIMG_5865.jpg
Check if your nozzle is partially blocked.
