power supply problem
I just finished assembling my acrylic i3 pro and there is no dc power. I have checked all the connections and the voltage selection switch is correct. The power switch lights but the led does not. I checked the input voltage 122 V, but the output only shows 35 mv.
zhangxueyou
Re: power supply problem
Hi, jay
Please take a picture of bottom of the power supply.
It appears to have been the voltage selection switch. I changed it to 220 v and applied 220v and it worked then I changed it back to 110v and applied 110v and it is working just fine. switch probably was not in full contact.
zhangxueyou
Good. If you have any problem later, please leave a post.
Good luck and enjoy your printing.
