Iam a newest in 3D Printer so thatI have jusut finished to assembly 3D printer and try to turn on the power but I found the problem ,I need your advise please. The board type is sanguinololu.
1. There is the alarm "MINTEMP" on the LCD screen(I think temperature of extruder) but I think I connect thermister correctly following from the instruction.
2. When I move the each motor axis X or axis Y or axis Z by in menu move in LCD screen but the all axis X,Y,Z move together all, I cannot to move asis only X or Y or Z for check the direction in each axis.
3. The motor axis Y move to home in wrong direction.
4. I try to move motor axis E Extruder but it is nothing movement I do not know how to check the motor E movement.
I am surely that I connect the cable follow to the intruction please to advise me to correct the problem.
Thank you very much.
Problem in Min Temperature and Stepping Motor
zhangxueyou
Re: Problem in Min Temperature and Stepping Motor
1.Please describe more specific: What is the first line and 4th line of LCD displaying? I think thermistor is not well connected, but I am not sure which one.
2. Please check if the connection of endstops are correct. 3. Y axis' moving direction can be changed in firmware. Do you have firmware? If not, please leave your email address, I can send you the firmware.
4. The extruder motor can not move unless the temperature of extruder is more than 180 degrees.
1. I remove and reconnect again,now it is ok.
2. I checked the connect of endstop of x , y and z ,there are correct as the following attached pictures, but the problem still remain.
3. Y axis moving in wrong direction, I do not have the firmware please send to sayanch@gmail.com and please tell me how to do.
4. Ok I will test the moving of E axis later.
Thank you for your advise.
- IMG_0158.jpg (228.46 KiB) Viewed 8805 times
- IMG_0157.JPG (183.35 KiB) Viewed 8805 times
- IMG_0156.JPG (192.91 KiB) Viewed 8805 times
- IMG_0155.JPG (190.73 KiB) Viewed 8805 times
I try to do follow this page http://www.geeetech.com/forum/viewtopic ... 20&t=16253 but there is the error as the attched picture. I do not know what can I do next?
Best Regards and Thank you a lot.
- Error.jpg (69.84 KiB) Viewed 8796 times
zhangxueyou
I can not see any file in Arduino1.0.1. You should drag all the files of firmware into Arduino.
Ok I understand now. Now issue 2 and 3 are correctly solved.
Thank you very much
Thank you very much
