i brought new Geeetech Dual Extruder Prusa i3 pro C kit lastmonth
My problem is both extruder stepper motor not working.I done all wiring as per manual.but
if i give any print both extruder get heat,but stepper motor wont push filament.if i push by hand
the filament flow through noozel.
Re: both extruder stepper motor not working
did you reburn the latest upgraded firmware?
No not reburn
you can have a try.and some customer have tested and it did help.shiva wrote:No not reburn
Thanks,I re burn frimwere,it started working,Thanks!
theCyanEYED
Didn't work for me
I don't know what I'm doing wrong
Maybe it's the problem of exruuder motor, extruder motor driver, or motor cable, check this post to see if there's anything wrong:
