LCD Display showing backlight and nothing else
IdioticAussie
Post by IdioticAussie »
Hello all,
When I uploaded the code to my G2S all that appeared on my LCD screen was the backlight. No rectangles, no display, nothing, just the light. Any suggestions?
Regards
IdioticAussie
Re: LCD Display showing backlight and nothing else
You can adjust the screw of the LCD controller to see if it works.
Or you have plugged the LCD wire to the SD outlet, try to swap them .
IdioticAussie
Mark wrote:You can adjust the screw of the LCD controller to see if it works.
Thank you very much, that fixed the problem
