firmware
johnz
firmware
Post by johnz »
Hello I have a Prusa Reprap Acrylic i3 it had a sanguinololu board but now I want to replace it with a GT2560 board ...what firmware should I flash the Gt2560 to work with the printer ??? please help....Thanks.
Re: firmware
Use the one for the I3X single extruder printer, and note the dimensions here:
// Travel limits after homing
#define X_MAX_POS 210
#define X_MIN_POS 0
#define Y_MAX_POS 210
#define Y_MIN_POS 0
#define Z_MAX_POS 180
#define Z_MIN_POS 0
Also the steps/mm here:
#define DEFAULT_AXIS_STEPS_PER_UNIT {78.74,78.74,2560,95} // MXL, Z M8=1.25, MK8
I think that might be enough.
johnz
Re: firmware
Post by johnz »
I did all that ,now my prints come out real small?? I did not change anything in Repetier as it was working great with the other board.
johnz
Re: firmware
Post by johnz »
also it wont print in the center, it prints on the side of the bed???
Re: firmware
now my prints come out real small??---have you changed the steps to those that in your original firmware?
And the bed center, you can try to calibrate it here:
