Prusa i3 Aluminium - Z Axis threaded rods
swittmann
Post by swittmann »
I'll start by saying this is my first 3d printer, and this is the first time I'm posting here.
I have a Geeetech Prusa i3 Aluminium.
I'm getting quite decent print quality + some terrible z banding.
With Z Supports
With Z Supports
I pulled the z supports off and ran the head up and down.
Without Z Supports
Without Z Supports
One of my threaded rods seems to move in large circles at the top where the other moves in a small circle.
The brass bush on the "wobbly" side is quite tight where the side that doesn't move around a lot can actually be wobbled in the bush itself.
I did a print of a calibration cube with no Z supports and it came out much better than with the Z supports on.
Has anyone created a part that does not hold the threaded bars in place for this printer?
Is there anything else that you would recommend to try and resolve this issue?
I found one on thingiverse for geeetech prusa i3 but it didn't fit this printer :(
Re: Prusa i3 Aluminium - Z Axis threaded rods
check your rods are bended or not, and the couplings on the Z axis, are the two holes of it line up with each other? how's the coaxiality?
archit3ct
Post by archit3ct »
Print these 2 brackets and remove the brass nut.
http://www.thingiverse.com/thing:1431036
They do a fantastic job.. The wobble is not transferred to the print.
mark2
Post by mark2 »
That looks like an excellent solution to the wobble problem!
How does the piece stay on the threaded rod? is it threaded itself? or does it have a captive nut?
I can't tell from the pictures
archit3ct
Post by archit3ct »
Check this item also. Same thing. More clear pictures and video
http://www.thingiverse.com/thing:1424358
I printed two myself and they are amazing.
X axis is free from the Z screws so its only moving on the rods
swittmann
Post by swittmann »
Much appreciated!
I purchased some new threaded rod which made very little difference.
I've printed out a couple of these but have not installed them just yet.
I'll install them over the weekend and see how it goes.
swittmann
Post by swittmann »
Before and After
So much better. Thank you :)
archit3ct
Post by archit3ct »
Like a new printer.
Glad it helped you
mark2
Post by mark2 »
Printed too myself, but not yet fitted.
My Z-wobble is less severe than yours swiftmann, because I have already done some mods - I printed some different couplers and suspended the threaded rods using race bearings at the top - but it is still there, and I still get squeaking, so will update the thread when I finally fit them
solder_guy
Post by solder_guy »
I'm in the process of build .. Would someone print these for me to save from building twice?
Thx
Rob
