M201 Bowden tube not staying attached to extruder
stevemcl
Post by stevemcl »
Hi, I've got the M201 duel extruder model, and the tubes from the extruder to the head don't stay in place,
when the extruders push the filament out, the tubes push out as well,
Is there a way to clamp to tubes to the extruder?
I'm just push fitting them into the extruder,
thanks,
Re: M201 Bowden tube not staying attached to extruder
stevemcl wrote:Hi, I've got the M201 duel extruder model, and the tubes from the extruder to the head don't stay in place,
thanks,
I guess you mean the PTFE tubes,are the two tubes all being pushed out?I think you need to plug it into the extruder hard.
Best Regards
Shane1234
Post by Shane1234 »
We had the same problem- turns out we had the brass nipples on the top when they should be on the bottom. There are teeth inside that hold the tubes in place.
20160810_180336 (1).jpg (396.57 KiB) Viewed 7233 times
