Print head not staying level to sides of bed
JSPrint
Post by JSPrint »
Got a Delta Rostock mini G2S Pro. When I centre my print head on the bed, and move the head in any x,y direction it lifts about 5mm. Can sombody please help me with this problem, because as long as that happens i cant print anything with this printer.
Re: Print head not staying level to sides of bed
Did you level your bed as the manual shows?
If you did,try to set the value in the picture to -5 have a try:
JSPrint
Post by JSPrint »
Thank you. Tried it, but had the same problem. got hold of settings in the firmware and after a lot of hours i got the problem solved. Thanks for the reply :D
Got a new problem since i tried to print in 2 colors. 1st color print perfect, but when 2nd color starts the heads lift to about 180 and print there and when 1st color prints again it lifts even more to end stops en then its chaos.
