Max temp error G2S Pro Delta
Wavey75
Post by Wavey75 »
I turn on my printer, connected to it, altered the height, disconnected. Opened the firmware to change the height there too, uploaded it to the GT2650 and exited out of that, went back into repetier, connected and homed the printer, then used preset 1 to bring it to within 2mm of the bottom and all hell breaks loose!!!
Code: Select all
22:41:51.328 : OpenGL version:4.0.0 - Build 10.18.10.4358
22:41:51.328 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_ARB_map_buffer_alignment GL_ARB_conservative_depth GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_SUN_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_ARB_texture_swizzle GL_EXT_texture_swizzle GL_ARB_texture_gather GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_ARB_transform_feedback2 GL_ARB_draw_indirect GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_ARB_framebuffer_no_attachments GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_ARB_texture_buffer_range GL_EXT_texture_buffer GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_INTEL_performance_query GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_EXT_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_base_instance GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_tessellation_shader GL_ARB_vertex_array_object GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_texture_cube_map_array GL_EXT_gpu_shader4 GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_shader_subroutine GL_ARB_transform_feedback3 GL_ARB_get_program_binary GL_ARB_separate_shader_objects GL_ARB_shader_precision GL_ARB_vertex_attrib_64bit GL_ARB_viewport_array GL_ARB_transform_feedback_instanced GL_ARB_compressed_texture_pixel_storage GL_ARB_shader_atomic_counters GL_ARB_shading_language_packing GL_ARB_shading_language_420pack GL_ARB_texture_storage GL_EXT_texture_storage GL_ARB_vertex_attrib_binding GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_texture_storage_multisample GL_ARB_buffer_storage GL_ARB_debug_output GL_KHR_debug GL_ARB_arrays_of_arrays GL_INTEL_map_texture GL_ARB_texture_compression_bptc GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_robustness GL_EXT_texture_sRGB_decode GL_KHR_blend_equation_advanced GL_EXT_shader_integer_mix GL_ARB_stencil_texturing
22:41:51.328 : OpenGL renderer:Intel(R) HD Graphics
22:41:51.328 : Using fast VBOs for rendering is possible
22:42:15.084 : Printer reset detected - initalizing
22:42:15.100 : start
22:42:15.100 : echo: External Reset
22:42:15.100 : Marlin 1.0.3 dev
22:42:15.147 : echo: Last Updated: Feb 22 2017 22:37:36 | Author: (Hogan, Delta)
22:42:15.147 : Compiled: Feb 22 2017
22:42:15.147 : echo: Free Memory: 3637  PlannerBufferBytes: 1232
22:42:15.147 : echo:V19 stored settings retrieved (378 bytes)
22:42:15.147 : echo:Steps per unit:
22:42:15.147 : echo:  M92 X160.00 Y160.00 Z160.00 E186.00
22:42:15.147 : echo:Maximum feedrates (mm/s):
22:42:15.147 : echo:  M203 X400.00 Y400.00 Z400.00 E45.00
22:42:15.147 : echo:Maximum Acceleration (mm/s2):
22:42:15.147 : echo:  M201 X5000 Y5000 Z5000 E5000
22:42:15.147 : echo:Accelerations: P=printing, R=retract and T=travel
22:42:15.147 : echo:  M204 P1000.00 R2000.00 T2000.00
22:42:15.147 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s),  Z=maximum Z jerk (mm/s),  E=maximum E jerk (mm/s)
22:42:15.147 : echo:  M205 S0.00 T0.00 B20000 X20.00 Z20.00 E5.00
22:42:15.147 : echo:Home offset (mm):
22:42:15.147 : echo:  M206 X0.00 Y0.00 Z0.00
22:42:15.147 : echo:Endstop adjustment (mm):
22:42:15.147 : echo:  M666 X0.00 Y0.00 Z0.00
22:42:15.147 : echo:Delta settings: L=delta_diagonal_rod, R=delta_radius, S=delta_segments_per_second
22:42:15.147 : echo:  M665 L196.00 R92.00 S200.00
22:42:15.147 : echo:Material heatup parameters:
22:42:15.147 : echo:  M145 M0 H190 B55 F255
22:42:15.147 : echo:  M145 M1 H230 B70 F255
22:42:15.147 : echo:PID settings:
22:42:15.147 : echo:  M301 P22.20 I1.08 D114.00 C1.00
22:42:15.147 : echo:Filament settings: Disabled
22:42:15.147 : echo:Z-Probe Offset (mm):
22:42:15.147 : echo:  M851 Z-2.00
22:42:18.583 : echo:SD init fail
22:42:18.630 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://firmware.ultimaker.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Geeetech Delta G2S Pro EXTRUDER_COUNT:2 UUID:00000000-0000-0000-0000-000000000000
22:42:18.784 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
22:42:18.784 : echo:Active Extruder: 0
22:42:18.784 : Begin file list
22:42:18.784 : End file list
22:42:18.815 : echo:Active Extruder: 0
22:42:56.462 : Error:MAXTEMP triggered, system stopped! Heater_ID: 0
22:42:56.462 : Error:Printer halted. kill() called!
22:44:04.998 : Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
22:44:06.046 : Printer reset detected - initalizing
22:44:06.046 : start
22:44:06.046 : echo: External Reset
22:44:06.046 : Marlin 1.0.3 dev
22:44:06.046 : echo: Last Updated: Feb 22 2017 22:37:36 | Author: (Hogan, Delta)
22:44:06.046 : Compiled: Feb 22 2017
22:44:06.046 : echo: Free Memory: 3637  PlannerBufferBytes: 1232
22:44:06.046 : echo:V19 stored settings retrieved (378 bytes)
22:44:06.046 : echo:Steps per unit:
22:44:06.046 : echo:  M92 X160.00 Y160.00 Z160.00 E186.00
22:44:06.046 : echo:Maximum feedrates (mm/s):
22:44:06.046 : echo:  M203 X400.00 Y400.00 Z400.00 E45.00
22:44:06.046 : echo:Maximum Acceleration (mm/s2):
22:44:06.046 : echo:  M201 X5000 Y5000 Z5000 E5000
22:44:06.046 : echo:Accelerations: P=printing, R=retract and T=travel
22:44:06.046 : echo:  M204 P1000.00 R2000.00 T2000.00
22:44:06.046 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s),  Z=maximum Z jerk (mm/s),  E=maximum E jerk (mm/s)
22:44:06.046 : echo:  M205 S0.00 T0.00 B20000 X20.00 Z20.00 E5.00
22:44:06.046 : echo:Home offset (mm):
22:44:06.046 : echo:  M206 X0.00 Y0.00 Z0.00
22:44:06.046 : echo:Endstop adjustment (mm):
22:44:06.046 : echo:  M666 X0.00 Y0.00 Z0.00
22:44:06.046 : echo:Delta settings: L=delta_diagonal_rod, R=delta_radius, S=delta_segments_per_second
22:44:06.046 : echo:  M665 L196.00 R92.00 S200.00
22:44:06.046 : echo:Material heatup parameters:
22:44:06.046 : echo:  M145 M0 H190 B55 F255
22:44:06.046 : echo:  M145 M1 H230 B70 F255
22:44:06.046 : echo:PID settings:
22:44:06.046 : echo:  M301 P22.20 I1.08 D114.00 C1.00
22:44:06.046 : echo:Filament settings: Disabled
22:44:06.046 : echo:Z-Probe Offset (mm):
22:44:06.046 : echo:  M851 Z-2.00
22:44:09.464 : echo:SD init fail
22:44:09.533 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://firmware.ultimaker.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:Geeetech Delta G2S Pro EXTRUDER_COUNT:2 UUID:00000000-0000-0000-0000-000000000000
22:44:09.533 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
22:44:09.533 : echo:Active Extruder: 0
22:44:09.533 : Begin file list
22:44:09.533 : End file list
22:44:09.548 : echo:Active Extruder: 0
22:44:36.979 : Error:MAXTEMP triggered, system stopped! Heater_ID: 0
22:44:36.979 : Error:Printer halted. kill() called!
Also, my stepper motors, stepper motor drivers and their heatsinks are very hot, burns my finger tips to touch them.
Any ideas on what on earth is going on?
bang
Re: Max temp error G2S Pro Delta
Post by bang »
What version of firmware did you upload?
And how did the temp for extruder and heatbed show on LCD?
Wavey75
Post by Wavey75 »
I used the correct version of the firmware for my G2S Pro.
The temperature of the extruder and heat bed were both 0.
I'm still trying to calibrate the thing.
I purchased it roughly 11 months ago. The support (or lack of) from the seller in Germany was appalling, so I have been spending my time sourcing parts online to replace the faulty ones from the seller, i.e. a replacement stepper motor, replacement stepper motor driver chips, etc.
I also had to rebuild the dual hot ends because they arrived longer than the other, and finding the little crimps to disconnect the thermistor from to disassemble it all and re-crimp back together again has taken a long time too.
I now have the task of started the initial calibration and bed levelling, but this very, very hot motors and driver chips is yet another new thing to just happen, despite the replacement driver chips being 4 to 6 months old and I have flashed the firmware many, many times since and it has never got this hot before.
This has been the worst 3D printer I have ever had the misfortune to buy ... and I bought a Makibox A6, and that worked better than this Geeetech G2S Pro 3D Printer.
The little crimps that connect to the auto level switch have snapped and the ends of those red wires have been disconnected from the switch, but not from the GT2650 board, it's possible this might have added to or even caused the heat increase, but I doubt it, as the ends of the wires were not touching, but still I will unplug it from the board while I am searching for the right sized 2.8mm female crimps to use to put that back together again too.
bang
Post by bang »
The temp for them is all "0/0" on LCD or something else?
Check this post to test your board:
viewtopic.php?f=22&t=18972
