Mecreator 2 extruder not heating
elite194
Post by elite194 »
Mecreator 2, Repetier 1.6.0, first unboxed and tried March 30, 2017
The extruder reads a temp of 0 and stays that way, both through Repetier and front control panel. The bed heating functions normally through software and control panel. The home function appears to be working normally. A test sample was found in the box.
Setup was done according to the online manual, baud rate, etc.
What should I check next, assuming the test print was not a problem, what did I miss?
Newopint95
Re: Mecreator 2 extruder not heating
Post by Newopint95 »
have you checked to see if the hot end is actually cold?
when you command the hot end do younhave voltage to the hot end heater leads?
is the thermister good?
elite194
Post by elite194 »
after trying a number of things, I finally unplugged it, let it sit for 2 days and then tried again and now it seems to be working
