Problem with 8mm and bearing x and y axis
attiliopiccolo
Post by attiliopiccolo »
Good mooring,
i have just finish my Acrilic prusa I3.
During the mount I check just a problem, two 8mm shaft don't work well in the bearing.
At the end of assembled the printer don't work well; the motors don't have the power to move the axis, also with had it not real free.
Re: Problem with 8mm and bearing x and y axis
Hi,you can check this post viewtopic.php?f=17&t=17038.
