Dual Head mount extruder on the extruder support
Fumacasa3D
Post by Fumacasa3D »
i try to assemble my new Prusa i3 Pro C Dual Head.
When I mount the pre-assembled extruder on the extruder support
the hot-end touches the screws of the extruder holder as seen in picture 1
so i cant fixing the extruder screw in the first hole
Picture 1
Hot End touch Screw
Hot End touch Screw
Trouble 01.jpg (107.66 KiB) Viewed 5775 times
I'I think the problem is, that the extruder has been changed and is now no longer high enough
Picture 2
Trouble 02.jpg (129.93 KiB) Viewed 5775 times
Picture 3
Trouble 03.jpg (27.81 KiB) Viewed 5775 times
Or have I done something wrong..?
Excuse my bad English ;)
Holger
pekote
Re: Dual Head mount extruder on the extruder support
Post by pekote »
I think that you have to fix the X axis plate first.
Then fix the the support plate for the extruder.
Finally, fix the extruder, to the support plate. In my case, as it was too close to the x axis plate, I fixed it to the second hole (there are three holes to choose).
Of course, there is an interference. For the case you want to remove the x axis plate, it is necessary to remove the extruder first.
Regards
Juan
