Glass Plate on the Mecreator 2
Moriis
Post by Moriis »
Hello all,
ich have i new 3D-Printer (Mecreator 2) an i am new in 3D Printing.
The Aluminium Bed on my ne printer is not plan/flat an i want to put an 3mm Glass-Plate on it.
The Glass-Plate is very good for me, for PLA it is OK and i can change 2 Glass-Plates between
2 prints very quickly.
My Question is:
I put the Glass-Plate (180x180x3mm) on my Aluminium Bed with small folding clips.
That is perfect and the Extruder have enough space to work. My Problem is, that the
Nozzle is too close on the Glass-Plate. When i press "Auto Home" the Z-Axis is too far up.
When i Print with 0.2mm i have little problems but when i print with 0.05mm the Nozzle
scratches over the glass-Plate.
I leveling the Bed with thy screws, but this is not all what i need to do.
Can someone explain to me what I need to do to adjust the height of the axis to the glass plate?
Many Thanks to you, Matthias
Re: Glass Plate on the Mecreator 2
Hi,you can adjust the position of the Z axis’s entstop according to you actual sitution.Here is the picture showing.
Mecreator2 endstop.png (167.62 KiB) Viewed 18319 times
Moriis
Post by Moriis »
Thank you, I adjust the switch now.
8ung
Post by 8ung »
Which maximum temperature you get with the glassplate??
LadyQ
Post by LadyQ »
[quote=William post_id=38177 time=1493004453 user_id=51382]
[/quote]
How do you do it .. the switch if fixed to back and no adjustment screws are seen
monrra
Post by monrra »
[quote=Moriis post_id=38160 time=1492864491 user_id=56493]
Hello all,
My Question is:
[/quote]
Hi!
Im thinking in buying a glass plate for my printer too but I would like to know if you were able to solve the problems that you describe and how you did it, please.
Thank you in advance.
orenjikuma
Post by orenjikuma »
You can just print a spacer so that it touches the endstop first.
https://www.thingiverse.com/thing:2017642
