Y layer shift
Y layer shift
Hi all.
I've a Geeetech i3X (Acrylic) and 'till now I haven't any big issues (1 year of happy printing!).
But, since a while (1 month or so), I'm experiencing a strange Y layer shift.
Attached my last print ...it's supposed to be a cube...
I tried to:
1) tensioned the belt (many tries).
2) changed the motor (I've swapped the Y motor with the X motor).
3) checked the motor current and even changed the motor driver.
The problem still occours...
The strange fact is that it happens sometimes: I've tried different objects in different placing and it seems that there isn't a systematic issue.
The bed seems to move freely on the axis.
Do u have any clues??
Thanks!
E
I tried to:
Thanks!
E
- 02.jpg (113.85 KiB) Viewed 19875 times
- 01.jpg (85.89 KiB) Viewed 19875 times
Re: Y layer shift
check the cable going from the controller board to the stepper motor. Since there is no feedback mechanism from the motor to the controller, if the controller tells the motor to move and it doesn't you could see artifacts like this. The Z motors are the only motors that shouldn't have wear issues with the cabling but all the other motors have their cabling moving and over time they could fail. My extruder cable failed after about a month of use. Good luck.
Re: Y layer shift
Thz rotormansa!
Actually the cable is the only part I didn't checked or switched.
So, to give a try, can I switch it with one of the Z axis?
Or I can switch with the X axis and check if it will shift on that direction
But why is it so random?
For example, yesterday I printed a piece (2 hours) without a single shift.
Re: Y layer shift
the cables are all wired the same (or they should be... long story but mine shipped with one wired backward). So just swap out the Y for one of Z cables.
The motors have two fields at 90 degree angles. The controller applies a current to one field then to the other field, to move in the other direction they just reverse the order. The problem happens when the other field doesn't get the current driven to it's field so the motor takes a small step forward then when the other field is supposed to drive it the rest of the way the motor falls back to the original position. Happened on my extruder and is called skipping. On the Y or X I think what you're seeing would happen.
Let me know how it works out.
rotormansa
rotormansa
Re: Y layer shift
unfortunately I had the same problem.
I've switched the Y cable with one of the Z axis and the result is the same.
Now I've rotate 90° left the piece, I'd like to see if the shift will occour on the X axis...
Then I'll try switching the cable with the other one of the Z axis.
- 03.jpg (117.57 KiB) Viewed 19845 times
Re: Y layer shift
the strange part of this is that:
1) my first attemp of printing that piece I had a Y shift.
2) the 2nd time the shift occours on another heigth.
3) then I printed another object and it was fine.
4) the 3rd attempt the shift occours at the same height of the 1st attempt.
5) after swapping the Y and Z motor cable, I had again the same result of the 1st attempt
(maybe in the image it's much more clear
- 04.jpg (141.55 KiB) Viewed 19845 times
Re: Y layer shift
Anything electrical running new in the house? I'm an amateur radio operator and my transmitter caused my printer to lock up.... surprised me.
As stupid as it sounds, re-program the controller?
I recently upgraded Repetier and caused weird quality issues, went back to the previous version and things got better. No issues like you are seeing.
Try running the Y bed back and fourth with gcode you edit and make sure after 200 or 300 iterations the bed ends up in the same place at the end of the gyrations.
rotormansa
rotormansa
Re: Y layer shift
I recently upgraded my Repetier version to 2.0.
I've restored the 1.6.2 but result is the same (just printed: same Y layer shift).
I've give a try to Simplify3d: will come back.
Re: Y layer shift
It turns out that it was the slicer OR Repetier (both 1.6.2 and 2.0.0).
With Simplify3d I was able to print the object correctly...
Now I've to try the other one that have the same shift problem.
I'm not able to understand what happens: after tons of different printed object, I found 2 different figures that cause a semi-sistematic Y shift layer...
Thanks!
Thanks!
