It is normal, for the pin, to fall due to the vibrations during the infill process?
Any suggestion or help to avoid it?
Thanks in advance.
Mariano.
3dTouch problem
Re: 3dTouch problem
Hi,could you post some videos to show how do the pin fall due to the vibrations?
Re: 3dTouch problem
you can see the accidental deploy at second 9.
https://youtu.be/5Jmm46Bd0LM
The pin fall, touch the bet and not go up.
Thanks for your help.
Re: 3dTouch problem
After watching this video,I think it's because the magnet at the top of the probe is short of magnetic force.So here are some tips for you.mgros wrote:you can see the accidental deploy at second 9.
1、Change a new probe,especially the magnet inside the sensor;
2、Adjust the screw on the top of the sensor a little higher,like the picture showing.
- QQ截图20170522172409.png (255.09 KiB) Viewed 7077 times
