Connection and print fails with Windows 10
gpau
Post by gpau »
Easy Print does not print, the com serial port is recognized because it feels the connection signal with the PC, but when the print order prints the Geeetech i3 Pro C does not start. Is not Windows 10 a problem or a driver?
Thank you
Re: Connection and print fails with Windows 10
You should ensure the drive install correct and open the bottom of power
gpau
Post by gpau »
When I start the program and go to the printer hyphen button, geeetech is recognized by the PC, but when the print order does not print.
It sounds weird that it does not work on two PCs.
Thank you
hnswbr
Post by hnswbr »
Please help me I have the same problem. I tried everything, I am exhausted
Hi,hnswbr
You need to attach more details of it.
Then we can help to check it.
1.The PSU output is 12V/24V.
2.Try to replace the old PSU then test it again
3.Refer to this post and install the drivers for your win10
http://www.geeetech.com/forum/viewtopic ... 974#p81974
hnswbr
Post by hnswbr »
William wrote: Thu Apr 11, 2019 2:05 pm Hi,hnswbr
William you a good guy. You saved my life.
