GeeeTech Rostock Mini G2S Pro Concave Offset
skymen
Post by skymen »
helloo,
almost get the printer ready to print, but there's one issue.
if i try to offset the Concave Convex of the bed nothing happens
(For each 1.0 unit increase or reduce of the DELTA_RADIUS, the z printing volume
will increase or reduce 0.2 unit)
#define DELTA_RADIUS
(DELTA_SMOOTH_ROD_OFFSET-DELTA_EFFECTOR_OFFSET-DELTA_CARRIAGE_OFFSET+1)
the nozzle touch the bed at 0.3 z, so i thought i set it to 0 but nothing happens
any of you a idea of what i could be ????????
i upload it with Arduino 1.0.6
Greetssss from Holland :D
Re: GeeeTech Rostock Mini G2S Pro Concave Offset
Maybe you should check the configuration.h in these lines
You should ensure Z-offset value is under this range
skymen
Post by skymen »
I check the settings, it was too high
Both are 25
But if i change the settings, must i repeats the steps for calibration?
You should set the value to -5 to 15 and recalibrate
skymen
Post by skymen »
heej
i change the settings to -5 and 15 and recalibrate the printer
still nothing happens :( tryed different values.
the nozzle is still at the same high by z: 0
about 2mm from the bed
skymen
Post by skymen »
Still trying to get the concafe offset but nothings happens
I have no ideaa what to do :'(
You can increase the range of Z max
skymen
Post by skymen »
Must i change the z high only in the program( repetier host ) or also in the software???
Gr
Skymen
Both are needed
skymen
Post by skymen »
Finally succeed to calibrate the printer correctly. The next problem is that the motor on the top ( dont know the name of it. Xd) stop pressing the filament to the hotend.
There is nothing comming out the nozzle. Only when i pressed the filament with my hand down to the motor it wil come out the nozzle :s
