UI files for A30/The screen displayed not correct or black screen
Hi, guys! :D
Guide of it----------------------------------------------
1.How to open the A30 power box?
You can refer to it:
https://www.youtube.com/watch?v=Ij3CnQ2ICsc
2.Download the correct A30 UI files:
Notes:Fixed the problem with portion UI display not correctly
Update:New Ui for A30 v1.36.57 later(stable)
A30 UI files after 1.36.37.zip
(606.6 KiB) Downloaded 2376 times
MD5:
3.You need to delete the old A30 UI files on the sd card
4.You should copy these unzip files to the root of the sd directly
LCD UI-1.png (10.42 KiB) Viewed 43184 times
6.Re-insert the sd to LCD sd card slot.Done!
The new version of the A30 UI files:
A30-UI(V3).rar
(515.1 KiB) Downloaded 2178 times
The old A30 UI files:
A30-UI(V1).rar
(928.04 KiB) Downloaded 1605 times
The oldest firmware Ui files(Not recommend to use it)
A30_UI.zip
(664.65 KiB) Downloaded 1591 times
Octagonman
Re: How to fix-A30>The screen displayed not correct or black screen
Post by Octagonman »
Ok I followed the steps and got the screen working again. But now the heated bed won't stop heating up as soon as I turn the printer on. Even with no print active it will heat up to 95C. And with a print in progress it will pass the bed temp of 50 and keep going higher the entire time. It's gets to 80 quick then slowly higher till I power off the whole machine.
Have you tried to "default factory"?
Octagonman
Now I have done the factory default and the same is true. As soon as the power is on, the bed started heating up. The temperature reads accurately as well. I don't even have to be printing anything, the bed starts heating when it boots.
gamura
Re: UI files for A30/The screen displayed not correct or black screen
Post by gamura »
Please dont use rar, I cant open it on any of my machines. And these instructions are weird tbh. What should I do with the "new ui" files?
Lexan
Post by Lexan »
winrar is free to use for every os, so may you check that first.
whats wrong with these steps ?
gamura
Post by gamura »
Okay, I just managed to open the rar files... and it took me a while to realize, that you have to store them on the internal SD. Not the removable one^^.
gamura
Post by gamura »
Why not use zip which is free in terms of open source and suppoted out of the box on every os? Winrar is closed source and a somewhat shitty compression tool^^. I thought it would be dead since the ages of p2p filesharing.
philipazi
Post by philipazi »
I just got a new A30 printer but it doesn't display anything. The power LED light is showing but there is nothing on the screen. I downloaded the files here and replaced the old ones but I still have a black screen. I noticed the motor / fan also doesnt spin continuously. The fan/motor seems to start and stop each time. Are they supposed to keep spinning once plugged in or is this just a black screen problem? What advise can I get please?
Hi, then the temperature displayed on your screen is the temperature at which the hotbed is heated? You can try unplugging the hotbed line and see how the temperature is displayed.
If the temperature still shows the heating temperature, it is a problem with the motherboard.
Locked
