XYZ printSize
MAK Gravy
XYZ printSize
Post by MAK Gravy »
Please tell me.
Printing with Rostock 301 but printing the actual dimensions small.
Design dimension X 31 mm ⇒ print size 28 mm
Design dimension Y 23 mm ⇒ print size 21.5 mm
Design dimension Z 7 mm ⇒ print size 6.5 mm
jan1995
Re: XYZ printSize
Post by jan1995 »
Bad after-sales service 04/01/2004 to 2018
Re: XYZ printSize
You should calibrate and increase the number of stepper motor steps per 1mm for each axis, respectively.
Correct this parameter until you get the right real dimension.
